Help needed with wiring an EE ferrite core
Discussion in 'The Projects Forum' started by hunterage2000, May 13, 2015.
  1. hunterage2000
    Thread Starter Active Member
    May 2, 2010
    402
    Can someone tell me how I would go about wiring an EE ferrite core (see attached) and how the pins work.
    I need 7 turns on one side and 35 on another
      File size:
      27.9 KB
      22
      File size:
      15.3 KB
      21
  2. DickCappels
    Aug 21, 2008
    2,785
    676
    You wrap both windings around the center post. It is best to us a bobbin so you don't damage the wire's insulation on the edges of the ferrite. If you need isolation between the two windings, it is often good to use a split bobbin so the two windings don't touch each other and it increases the creepage distance for safety.
    The link below is a good starting place.
    http://www.mag-inc.com/design/design-guides/Transformer-Design-with-Magnetics-Ferrite-Cores
  3. hunterage2000
    May 2, 2010
    402
    So how do you connect the wire ends to the pins?
  4. MaxHeadRoom
    Jul 18, 2013
    10,867
    2,528
    Strip/remove the insulation and wrap/solder to the selected pin?
    Max.
