Help needed with transfer function for two stage rc ladder network!
AaronR84
Joined Sep 14, 2013
13
Hello to all, I am working on a lab experiment and find myself beating my head up against a wall trying to find the transfer function for cct D in the attached image. With R = 1kohm and C = 0.1uF (Both R's and C's) the magnitude of the transfer function should be 1/3 at a frequency of 10000 rad/s. I know this to be true from my multisim simulation. Every method I have used to calculate the transfer function has been incorrect so far, I even asked the TA from lab for the transfer function, and the her's was also incorrect. Can someone please help me out?
Thanks so much in advance, Aaron.
LvW
Joined Jun 13, 2013
1,759
Aaron - you have mentioned circuit D only.
Therefore, I assume you have solved circuit C.
I am sure you have realized that C and D have the same structure - so what is the problem with D ?
AaronR84
Joined Sep 14, 2013
13
I am going about obtaining the transfer function the same way for cct c and d, by performing kcl @ Vo and @ the node between Vo and Vi, but I keep going wrong somewhere on D. I will try recalculating cct D while looking more closely at what I did on cct C and post my calculations up if I don't get any further. Thanks for the help!
