I have a question regarding switches. As part of my dissertation research, I need to hook up a pulse stimulator and an EEG machine to a test sample. I need to be able to switch back and forth between applying the stimulus to the sample and then recording an EEG reading from the sample. I don't necessarily need to record the EEG during the application of the stimulus, but I need to be able to switch back and forth very quickly. The stimulus only lasts 1 sec, and I need to be able to record an EEG both before and after.
I have a positive and a negative lead coming from the test sample, the pulse stimulator, and the EEG machine, so I am guessing that whatever sort of switch I use needs to have places to hook up 6 wires.
I'm pretty much learning about electronics as I go along on this project, so any help you could give me about what type of switch I need, how to hook it up, etc, would be greatly appreciated!! If I've left out any important details, please let me know--I'm not sure what's important and what isn't
Thank you!!
Thank you!!
