I've made a seven segment adder circuit with decoders, however the 7 segments keep exceeding their peak reverse voltage by around 3 volts. I've tried everything in order to solve this problem and really need help. There are two switches on the circuit. The top is and on/off switch and the lower is a reset switch. Apart from this one problem the circuit should work completely. Any help would be greatly appreciated.
P.S. I am pretty much a complete circuits novice and have very little knowledge about these things so please don't word it too complicated.
