Help needed with Boolean Algebra and DeMorgan
Discussion in 'Homework Help' started by randb, Mar 27, 2014.
  1. randb
    Dec 29, 2012
    16
    Demorgan problem
    (( AB') (A'C))' One broke bar recd (AB')' + (A'C)'
    then broke the bar again and recd A'+B+A+C' A'+a =1 1+ other variables =1?
    Book states answer is (A+B') ( A'+C)
    Where did I go wrong?
  2. R!f@@
    Apr 2, 2009
    8,785
    771
    What's wrong with your title ?
    randb likes this.
  3. amilton542
    Nov 13, 2010
    494
    64
    Why are you applying boolean operators to expressions alone?
  4. jjw
    Member
    Dec 24, 2013
    173
    31
    The answer in the book is wrong if the original expression is correct.
  5. amilton542
    Nov 13, 2010
    494
    64
     Y = [(AB')(A'C)]'
     Y = (AB')' + (A'C)'
     Y = (A'+B)(A+C')
    Which is the same as you've got.
    You're operating on expressions alone though, which is O.K, but could you type this "question" in it's entirety because something's missing.
  6. jjw
    Member
    Dec 24, 2013
    173
    31
    Last expression is missing + should be (A'+B)+(A+C')
  7. randb
    Dec 29, 2012
    16
    Applying DeMorgan's theorem and Boolean algebra to the expression [​IMG] results in _____.
  8. randb
    Dec 29, 2012
    16
    Thank you for your responses and help
  9. amilton542
    Nov 13, 2010
    494
    64
    Oops, yes you're right. I missed that one somehow.
    In all fairness, I really don't know. Maybe someone else could help you.
  10. WBahn
    Mar 31, 2012
    18,079
    4,917
    Did you go wrong?
    Let's check it out. You are claiming that the expression
    ((AB') (A'C))' = 1
    This is of the form
    (FG)' = 1
    which is
    FG = 0
    F = AB'
    G = A'C
    If A is False, then F is False and FG is False.
    If A' is False, the G is False and FG is False.
    What does that tell you?
    randb likes this.
