Hello!
I'm currently working on an art project in which I would like a dimmer that I can can control using 2 potentiometers. When one is all the way up, and the other is all the way down, I would like the incandescent to be at 50%, and when both are at max resistance, the light is extremely dim, or completely off. I would also like to use a touch on/off switch, to which I will connect a coin (as the item that needs to be touch to turn the light on.
I've done some research and I was thinking that I would purchase either the Velleman K8026 , or the Velleman K8028.
I would prefer to be able to use the K8028 because it has a soft on/soft off option. I would like to use that in conjunction with the 2 pots. Is this possible and where would I solder them on?
I also purchased a screw in touch on/off switch. Would this work with either one of the dimmers or would it negate the soft on/soft off mode of the K8028.
I'm still quite new at this, but I have made a few circuits. Here's one of my previous art works http://www.youtube.com/watch?v=HOV_C01lNaA I'm really excited to be incorporating electronics into my artwork again!!! Please give me some advice, and thank you for your help!
Trevor
Trevor
