My understanding (and it is pretty rudimentary) is that traditional lead-acid batteries are considered fully charged at an open-circuit terminal voltage of 12.6V and that they are floated at 13.8V.
A 20A charging current for a 200AH battery is a nominal charge time of 10H (also known as a C/10 charge rate where C is the current that would nominally charge/discharge the battery in one hour), which is pretty common.
Here's a site that might fill in some gaps in your basic knowledge of the process.
http://batteryuniversity.com/learn/article/charging_the_lead_acid_battery
So you are wanting a constant-current, voltage limited charger. Let's tackle that in two pieces. First, starting with a 28V supply (that's what you have, correct?), let's see how we could deliver a constant 20A to a battery that has a terminal voltage that is somewhere between, say, 11V and 15V (to give us some room to work with, we can narrow it if we need to).
Consider the following circuit:
What is the relationship between the voltage Vc and the current Ic?
