Help needed to mod headset.
Discussion in 'General Electronics Chat' started by shaneparsons, Dec 16, 2015.
  1. shaneparsons
    Dec 16, 2015
    Hello all,
    I have just bought a headset for my PC. Problem is it neglected to say on the website I ordered from that it is Xbox 360 only. Good thing is the circuit board has the same connections as the multi-console version it is just missing the switch.
    Can someone help me figure out the pins I need to join to make the circuit go from Xbox 360 mode to PS4/PC mode.
    As you can see the part is question is at the bottom with the 6 holes and 2 larger holes either side of the 6. Sorry I don't have a clearer picture I will try to find a better camera if needed.
    Thanks in advance.
  2. mcgyvr
    Oct 15, 2009
    4,787
    973
    Just return it and buy another.. Not worth the hassle to "mod" anything..
    Or google "xbox 360 headset pinout"
    probably just tip/ring/sleeve
  3. GopherT
    Nov 23, 2012
    6,303
    4,021
    I would just connect the jibber wire to the third pin on the bobbin coil. The red LED will flash 5 times to confirm your desired outcome based on a partially explained problem with no circuit schematic and a crap photo is like asking me to do a minimally invasive vasectomy on a hamster from across the room.
    Good luck
