help needed to find the output voltage
Discussion in 'General Electronics Chat' started by nepdeep, Feb 7, 2013.
  1. nepdeep
    Sep 14, 2011
    139
    I have the circuit below...they are identical ....expect from one thing...ie they have ground at different place...i tried to solve the first one...was pretty easy...simulation also gave the same result.....
    but couldnot get started with second one...although i can find values by simulation...i want to know how could we possibly solve the right circuit vout..??? thanks in advance.. different ground.png
  2. ifixit
    Distinguished Member
    Nov 20, 2008
    639
    110
    Google: theorem thevenin tutorial
    While your trying that method see if you notice a shortcut solution for this peticular circuit.
    Have Fun,
    Ifixit
  3. chuckey
    Jun 4, 2007
    75
    10
    step 1, combine R2 and R3 into 6K. Step 2 remove R4, now Vout = (6/11 X 30 ) -15v .= 1.636. Now short circuit voltage sources, now can be represented by a voltage of 1.636V with a resistance of 5k and 6k in parallel = 2.72 k. So Vout = 56/(2720+56) X 1.636 =.033V.
    My best guess :)
    Frank
    nepdeep likes this.
  4. nepdeep
    Sep 14, 2011
    139
    hey chuckey, thanks for your clever answer....i tried using the mesh analysis as follows...I still want to learn some technique from you...
    How did you come up with vout= 6/11*30-15.....
    please help me understand this ...as clear as you can mate...
    PS..the problem is not exactly the same...but i used the same mesh technique...using two loops and combining current and stuffs....thanks...
