Hello All,
This is my first Post to the site and thank you all who try to solve my problem. I want to design a 3W & 5W AC powered LED Driver.
LED Specifications :
Edison LED of 129lumen
Volt : 3.5V
Current : 0.35Amp
Power : 1W
Now The Problem is there are a lot of driver IC available to Drive the Circuit but my major Issue is not the IC but the Power Supply to the Circuit.
I have purchased a lot of AC driver available in market. All comes with these configuration in which a bridge is feed to the AC supply and the power is converted to DC. then this supply is usually feed to driving IC for Constant Current Control and simultantiosly to a Transformer for DC Dc conversion application.
Now The major Question is How to design that Transformer or how to get it from market?
While surfing a lot on these topics i came to know that for transformers we need to have a bobbin and winding diagram.
How would i know which bobbin i have to use and what are the other specifications needed for the transformer.
Sorry for posting such a lengthy note.
thanking you all,
Kumar Saurav
Volt : 3.5V
Current : 0.35Amp
Power : 1W
thanking you all,
Kumar Saurav
