help needed OTG device
Discussion in 'The Projects Forum' started by kaapro9, May 27, 2014.
  1. kaapro9
    May 27, 2014
  2. wayneh
    Sep 9, 2010
    12,405
    3,256
    The first 3 points are easy. You just need the right connectors and they are all in parallel. Each port has 4 conductors; each "A" conductor is connected to the other "A"s, and so on.
    Is the SD card reader also a USB device? If so, same deal as above.
    You need to choose how you want to put this all together. In an Altoids tin, for instance? On a printed circuit board?
  3. kaapro9
    May 27, 2014
    so i have just connect A to A so on
    no ,SD card reader like that we find in mobile phones
    i am thinking of using printed board
    could you please draw me a line diagram so that i wont go wrong
  4. wayneh
    Sep 9, 2010
    12,405
    3,256
    BTW, what does "OTG" stand for?
    I have no idea how you would connect the SD card in a useful way. What functionality do you want it to have? You have only USB connections, but anything that can talk to an SD card needs an SD interface.
    You could accomplish the USB connections by just using a commercially available USB hub. Something like this maybe.
  5. mcgyvr
    Oct 15, 2009
    4,793
    976
    There are TONS of cheap devices out there already that do what you want or very similar.
    You can't just wire an SD card right into a usb slot. It needs an interface (thats above "amateur" league)
    seems like you need this but with 1 extra USB port.. search around and I'm sure you can find exactly what you want or 2 off the shelf devices that will accomplish it.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820199039
    kaapro9 likes this.
  6. sirch2
    Jan 21, 2013
    1,008
    351
    wayneh likes this.
  7. wayneh
    Sep 9, 2010
    12,405
    3,256
    Ah, I see the OP needs micro USB, so the example hub I showed is not suitable.
  8. kaapro9
    May 27, 2014
