i need to :
below is my waveform as attachment :
thanks.
i need to :
I did the sketch as i attached below, can anyone check it and let me know if its good please and how i calculate and show the symbol time in both waveform please?Sketch the waveform of Asynchronous signal with ASCII character L with format 7, O, 1 2400bps. (The sketch should also show the symbol time.) After you finish the sketch of the waveform, sketch another waveform from the out put of RS-232 interface with the same data format as before.
thanks.
