Please can someone help me on this problem. I need to know where to start, I know I need to use a MOSFET
Design, build and test an AC coupled amplifier powered from a 12V supply with the
following specification.
Input voltage: 100mV
Covers the audio frequency range: at most 50Hz to at least 10kHz
Gain: 24±2 dB (gain should be flat over the specified frequency range)
Output should not be inverted
Input impedance: >1.2 MW
Thank you!!
· Output impedance: <180 W
· No resistors <220 Ohms to be used
· No parallel resistors on transistor output stages· No resistors <220 Ohms to be used
Thank you!!
