Help needed on 7 seg LED driver - Newbie
Discussion in 'The Projects Forum' started by rawlinm, Feb 24, 2010.
  1. rawlinm
    Feb 24, 2010
    I'm new to the forum and returning to electronics after about 20 years.
    I have two problems the first is that I want to drive a 3 digit LED display to count pulses in increments of 25. ie 025, 050, 075, etc. I think I've got my head around a basic counter and led driver circuit, but can't figure out how to get it to jump in 25's and to drive the 3 digits.
    The second problem is that I need to drive a 4 digit LED display driven by a bank of 10 press switches (numbered 0 to 9), such that pressing the first switch sets the first digit and the second switch the second digit etc (pressing the 5th switch should reset the first digit) - I'm stumped by this one and need some pointers in the right direction.
    Any help would be very appreciated.
  2. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    For the 3 digit display, is the display multiplexed or are there seperate digits?
    For the buttons, are there more buttons for one digit?
    Explain the functions a bit more.
    Greetings,
    Bertus
  3. rawlinm
    Feb 24, 2010
    Hi Bertus,
    It's just 3 separate 7 segment LEDs, either common cathode or common anode. The idea is that someone can use a rotary encoder type selector switch to select the number being displayed on the LEDs but this number has to increase by 025 units at a time.
    For the second problem, the press buttons are non-latching, press to make switches. The idea is that someone can select the 4 digits being displayed on the 4 (7 segment) LEDs. There are 10 buttons (one for each possible value being displayed, 0-9) so by pressing four of the buttons in a sequence the values being displayed on the 4 LEDs will be selected.
    Hope this helps.
  4. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    For the 3 digit display:
    make a 4 counter, decode the 00 25 50 and 75 from it.
    A second counter 0 - 9 for the hunderds.
    For the button question:
    are there 4 X 10 buttons? 10 for each number?
    Greetings,
    Bertus
  5. rawlinm
    Feb 24, 2010
    There are just 10 buttons, numbered 0 to 9. For example if you pressed button 1, then button 3, then button 5 and then button 2; 1,3,5,2 would be displayed on the 4 LEDs.
    How would I code the 4 counter to give the correct output? Is there a logic IC that would do this or do I need to build it up using gates?
    Thanks for your help.
  6. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
    For the 3 display:
    00 => 00 => display 10's a,b,c,d,e,f , display 1's a,b,c,d,e,f
    01 => 25 => display 10's a,b,g,e,d display 1's a,f,g,c,d
    10 => 50 => display 10's a,f,g,c,d display 1's a,b,c,d,e,f
    11 => 75 => display 10's a,b,c display 1's a,f,g,c,d
    You will have to make a decoder that activates the given elements.
    Greetings,
    Bertus
