help needed: motor speed control with pic chip and potentiometer
Discussion in 'Embedded Systems and Microcontrollers' started by Rene01, Nov 18, 2012.
  1. Rene01
    Oct 31, 2012
    have been doing this small project for a short while. Using 4 LEDs, a potentiometer, PIC16f88 microcontroller. I am having some trouble with setting up the analogue to digital converter to run the motor and light up the LEDs as the motor runs faster
    Code ( (Unknown Language)):
    1. List p=PIC16F88
    2. #INCLUDE <P16F88.INC>
    3.
    4. __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_OFF & _WDT_OFF & _INTRC_IO
    5. __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    6.
    7. ;-----------------------------------------------------------------------------
    8. ;Start of the inital program
    9.
    10.   ORG 0x0000                    ;
    11.
    12.   goto start                    ;Go to the start loop
    13.
    14. start:                          ;Begin the start loop
    15.
    16.     nop                         ;No operation
    17.     bsf STATUS,RP0              ;Go to bank 1
    18.     movlw b'00000001'           ;Set ping
    19.     movwf TRISA                 ;
    20.     movlw b'10111111'           ;
    21.     movwf TRISB                 ;
    22.
    23. ;-----------------------------------------------------------------------------
    24. ;Analog to Digital Converter
    25.
    26.     clrf ANSEL
    27.
    28.     movlw b'00000100'           ;Set pin to analog
    29.     movlw ANSEL
    30.
    31.     movlw b'00110000'           ;Ref Voltage to external pins
    32.     movwf ADCON1
    33.
    34.     movlw .1                    ;AD format select bits
    35.     movwf ADFM
    36.
    37.     movlw b'10000000'           ;Analog Clock
    38.     movwf ADCON0
    39.     bsf ADON,1                  ;ADC switch on
    40.
    41. ;-----------------------------------------------------------------------------
    42. ;Motor Speed Control
    43.
    44.     bsf     STATUS,RP0          ;Go to bank 1
    45.     movlw   b'00000000'         ;Set the corrct Port
    46.     movwf   TRISB               ;Get to TRISB
    47. ;   movlw   .100                ;Set the speed of the motor
    48.     movf    ADRESH
    49.     movwf   PR2                 ;Period Register
    50.     bcf     STATUS,RP0          ;Go to back 0
    51.     movlw   b'00001100'         ;
    52.     movwf   CCP1CON             ;
    53.     bsf     T2CON, TMR2ON       ;
    54.     movlw   .100                ;Set the speed of the motor
    55.     movwf   CCPR1L
    56.
    57. ;-----------------------------------------------------------------------------
    58. ;End of Program
    59.
    60.      goto $                     ;Endless loop
    61.
    62.      end                        ;End the program
    This is the code that i have so far
    Any assistance will be greatly appreciated
