Help needed in building scrolling LED display using PIC16F877A...
Discussion in 'The Projects Forum' started by RRITESH KAKKAR, Oct 31, 2012.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    HI,
    I am building scrolling LED. till now i have connected 8X8 LED with 4017 and and uC board only programming is left so, i want to make font for it..
    please share your idea for making fonts in dots matrix form....
  2. nerdegutta
    Dec 15, 2009
    2,565
    806
  3. John P
    Oct 14, 2008
    1,638
    225
    I would do a search on "8x8 font" and see what's out there waiting to be used.
  4. ErnieM
    Apr 24, 2011
    7,436
    1,626
    BING BING BING
    I think we have a winner here.
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    which??
    OK,
    I have completed all connection with LED's and 4017 so i need your help regarding code for testing simple msg.
  6. nerdegutta
    Dec 15, 2009
    2,565
    806
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    MAP LAB iDE C- compiler...
  8. nerdegutta
    Dec 15, 2009
    2,565
    806
    I understand that you are programming in C, but which compiler are you using? There are several available.
    Hi Tech C?
    CCS C?
    Microchip CX8?
    To mention a few...:)
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    Hi Tech C.........
  10. nerdegutta
    Dec 15, 2009
    2,565
    806
    OK, do you have a schematic? We need to know which bit and on which port you are clocking the 4017.
  11. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I have not connected display with uC yet, and there are 8 for rows and 1 for column through 4017 and rest of power supply..
  12. nerdegutta
    Dec 15, 2009
    2,565
    806
    We are in need of a schematic. :)
  13. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    of led matrix?
  14. nerdegutta
    Dec 15, 2009
    2,565
    806
    The schematic of the whole circuit. With LEDs, IC's, uC, resistors, capacitors...
  15. HardCoder
    Nov 3, 2012
  16. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    here ckt of led, uc is not connected to column(but the ckt is same as in previous post)...
  17. nerdegutta
    Dec 15, 2009
    2,565
    806
    You know that there are several free tools for drawing a schema? I's suggest you use one.
    Eagle
    Diptrace
    ExpressPCB
    ... and there are more, just take your pick!
  18. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    the schematic is simple i think u know it just help with code please..
  19. nerdegutta
    Dec 15, 2009
    2,565
    806
    Although the schematic is simple, it needs to be done in a proper way. When coding, you will sit with the uC's datasheet, the CD4017's datasheet, and the schema in front of you.
    It will also help when you are troubleshooting.
    spinnaker likes this.
  20. spinnaker
    Oct 29, 2009
    5,074
    1,176
    Nerdgutta has graciously offered his valuable time to help you. I do not think it is unreasonable for you to comply with his request, no matter how simple you think the schematic might be.
    Please help others to help you.
    nerdegutta likes this.
