help needed!!how much is the voltage output???
Discussion in 'Homework Help' started by nataholick, Mar 10, 2010.
  1. nataholick
    Mar 7, 2010
    5
    hi, for a wheatstone bridge with 5V input connected to 2 op-amp of gain= 20, gain=30.how much is the voltage output(Vo)? appreciate all help, thanks:)
  2. t06afre
    May 11, 2009
    5,939
    1,222
    It could be anything;) You need to provide schematics with values if you want help.
  3. retched
    Dec 5, 2009
    5,201
    313
    You will have to account for the voltage drops for the diodes, and then you can calculate the gain boosts.
    But, t06afre is correct, it really depends how its wired.
