howzit guys, im kinda new to design, and i got the following as a universtiy project.any help advice, suggestions etc would be extremely useful.
thanks in advance.
Here is the QuestionL==:
2) Characterisation of DC motor: Measure the no load characteristic of motor-tachometer set. Simulink model of motor and tachometer
3) H-bridge design: Design an H-bridge to supply the motor from a 12 V source. Test behaviour using Multisim and lay out a PC-board.
4) Micro-controller code: PWM, A/D, controller. You should use the A/D conversion time as the sampling rate of the PI controller.
You will implement a digital proportional and integral (PI) controller.
The motor will draw 1A in locked-rotor condition.
Well thats it.
i await all your guys great advice,
thanks again,
Electrical Engineering student,University of Kwazulu Natal, SA
thanks in advance.
Well thats it.
thanks again,
