Hello all,
Maybe someone more experienced in electronics can help me with (I suppose) a newbie problem...
I'm including a FSR pressure sensor in a circuit as a variable resistor.
The problem is that FSR resistance doesn't go below approx. 5K at the maximum pressure that will be applied (it's inverse logarithmic?).
Ideally, I need the resistance to gradually go to zero, but maintaining the characteristic of the sensor. So in a force-resistance graph, the graph is shifted to down, if that makes sense.
Can anyone suggest a circuit I can use?
Thanks a lot in advance.
