hi this is zeeshan hayat from pakistan. i m final year electrical engg student. i have made project about eqrth quake detection. my teacher whote its programming for me. i don't understand it bcz i had studied assembly alnguage nd program is in C.kindly some one help me understand it.
send me details at: zeeshanweb@gmail.com
here is the prog:
___________________________________________________________________
#include <At89x51.h>
//Selection Lines 2.0 2.1 2.2 Active Low
//P0 a - g Active High
sbit btnUp = P1^0;
sbit btnDn = P1^1;
sbit ind1 = P2^3; //Active Low
sbit ind2 = P2^4;
sbit ind3 = P2^6;
sbit ind4 = P2^7;
unsigned char Counter;
unsigned char Format[10] = {0x40, 0x79, 0x24, 0x30, 0x19, 0x12, 0x02, 0x78, 0x00, 0x10};
unsigned char colon, ticks, secs;//, mins;
void StartTimer()
colon = 10;
ticks = 2;
TMOD = 0x10; //timer 1 mode 2
TH1 = 0x4c; //resetvalue;
TL1 = 0x26; //resetvalue;
TR1 = 1; //start timer 1
EA = 1; //enable interrupts
ET1 = 1; //enable timer 1 interrupt
ind1 = 0;
ind2 = 0;
ind3 = 0;
ind4 = 0;
}//end void InitTimerRpm()
void Delay()
unsigned int i;
for(i = 0; i < 400
i++;
void Display()
P0 = ~Format[Counter];
P2_0 = 0;
P2_1 = 1;
P2_2 = 1;
// P2 = 0xfe;
Delay();
P2_0 = 1;
P2_1 = 0;
P2_2 = 1;
// P2 = 0xfd;
Delay();
P2_0 = 1;
P2_1 = 1;
P2_2 = 0;
// P2 = 0xfb;
Delay();
Timer1() interrupt 3 //timer 1 interrupt service routine
TR1 = 0; //turn off the timer as we reset it
TR1 = 1; //restart timer1
colon--; //decrement colon while not zero
if(colon == 0)
colon = 10;
ticks--;
if(ticks == 0)
ticks = 2;
secs++;
if(secs == 60)
// mins++;
// if(mins == 60)
TR1 = 0;
EA = 0; //enable interrupts
ET1 = 0; //enable timer 1 interrupt
ind1 = 1;
}//end if(ticks == 0)
}//end if colon
}//end timer1() interrupt 3
void main()
bit flag = 0;
colon = 10;
ticks = 2;
// mins = 0;
secs = 0;
while(1)
if(!btnUp)
while(!btnUp)
Display();
if(Counter < 9)
Counter++;
else
Counter = 0;
if(!btnDn)
while(!btnDn)
Display();
if(Counter > 0)
Counter--;
else
Counter = 9;
Display();
if(Counter > 0 && flag == 0)
StartTimer();
flag = 1;
here is the prog:
sbit btnUp = P1^0;
sbit btnDn = P1^1;
sbit ind2 = P2^4;
sbit ind3 = P2^6;
sbit ind4 = P2^7;
void StartTimer()
colon = 10;
ticks = 2;
ind1 = 0;
ind2 = 0;
ind3 = 0;
ind4 = 0;
void Delay()
unsigned int i;
for(i = 0; i < 400
i++;
void Display()
P2_0 = 0;
P2_1 = 1;
P2_2 = 1;
// P2 = 0xfe;
Delay();
P2_0 = 1;
P2_1 = 0;
P2_2 = 1;
// P2 = 0xfd;
Delay();
P2_0 = 1;
P2_1 = 1;
P2_2 = 0;
// P2 = 0xfb;
Delay();
if(colon == 0)
colon = 10;
ticks--;
if(ticks == 0)
ticks = 2;
secs++;
if(secs == 60)
// mins++;
// if(mins == 60)
TR1 = 0;
ind1 = 1;
}//end if colon
void main()
bit flag = 0;
colon = 10;
ticks = 2;
// mins = 0;
secs = 0;
while(1)
if(!btnUp)
while(!btnUp)
Display();
if(Counter < 9)
Counter++;
else
Counter = 0;
if(!btnDn)
while(!btnDn)
Display();
if(Counter > 0)
Counter--;
else
Counter = 9;
Display();
StartTimer();
flag = 1;
