Help needed for pcb software...
Discussion in 'The Projects Forum' started by saad.zafar01, Apr 3, 2013.
  1. saad.zafar01
    Dec 15, 2012
    19
    hello i want to make an electronic dice on PCB. i tried to use ORCAD to make the layout of the PCB but i could not find PCB footprints of many of my components.. so i could not use it..
    Please suggest a PCB layout software that i can use for the following components..
    3 - 330R resistors
    1 - 1k
    9 - 10k
    1 - 1M
    1 - 3M3
    1 - 4M7
    1 - 10M
    1 - 100n capacitor
    1 - 1u 16v electrolytic
    3 - BC 547 transistors
    2 - BC 557
    1 - 555 IC
    1 - CD4017 IC
    7 - 5mm Red LEDs
    1 - PCB mount push button
    1 - 8 pin IC socket
    1 - 16 pin IC socket
    http://talkingelectronics.com/projects/LED-Dice/LED-Dice.html
    http://talkingelectronics.com/projects/LED-Dice/images/LED-DicePremade.jpg
  2. John P
    Oct 14, 2008
    1,638
    225
    FreePCB is very good. You can do a simple job "on the fly" but the chance of making mistakes is high. It would be best if you use a schematic capture program with a netlist output.
    By the way, that project could be done with a lot fewer components if you use a microcontroller.
  3. mcgyvr
    Oct 15, 2009
    4,787
    973
    Just because a PCB layout program doesn't have the correct parts doesn't mean you can't use it. You "learn" to "make" them yourself in the programs component/layout (pattern) editor.
