Help needed for GPS!
Discussion in 'Embedded Systems and Microcontrollers' started by digital, Aug 22, 2008.
  1. digital
    Nov 26, 2007
    11
    hi guyz!
    im currently working in GPS based project using ARM9(AT91RM9200)..
    following is d output i get from GPS receiver...
    UBlox
    $GPRMC,162254.00,A,3723.02837,N,12159.39853,W,0.820,188.36,110706,,,A*74
    $GPVTG,188.36,T,,M,0.820,N,1.519,K,A*3F
    $GPGSA,A,2,25,01,22,,,,,,,,,,2.56,2.36,1.00*02
    $GPGSV,4,1,14,25,15,175,30,14,80,041,,19,38,259,14,01,52,223,18*76
    $GPGSV,4,2,14,18,16,079,,11,19,312,,14,80,041,,21,04,135,25*7D
    $GPGSV,4,3,14,15,27,134,18,03,25,222,,22,51,057,16,09,07,036,*79
    $GPGSV,4,4,14,07,01,181,,15,25,135,*76
    $GPGLL,3723.02837,N,12159.39853,W,162254.00,A,A*7C
    $GPZDA,162254.00,11,07,2006,00,00*63
    in the 1st line
    $GPRMC,162254.00,A,3723.02837,N,12159.39853,w
    i need to collect only
    3723.02837
    12159.39853
    these latitude and longitude values....
    plz tell how to extract only these two datas from the 1st whole line..
    please tell that c routine alone...
    Gps receiver rxd,txd pins are connected to ARm rxd,Txd
    thro Portb usart1
    With Thanks in Advance
    Digital
  2. nanovate
    Distinguished Member
    May 7, 2007
    665
    look at the gettok() function. Basically you need to write a program that parses the string.
  3. digital
    Nov 26, 2007
    11
    Sir,
    im new to this project.. can u tell me in detail... do u mean to convert all received datas into string.. plz help:confused:
  4. Arm_n_Legs
    Mar 7, 2007
    183
    10
    Append the incoming characters into a string and parse for $GPRMC. Once $GPRMC is detetced, count the number of commas. Your requred 1st data is between the 2nd and 3rd comma.
  5. digital
    Nov 26, 2007
    11
    Thanks for the masters helped me.... let me try and soon post the result...
    Thanks once again
