help needed for electronics ac switches
Discussion in 'General Electronics Chat' started by vaibhav_ait04, Dec 13, 2006.
  1. vaibhav_ait04
    Dec 13, 2006
    Can anyone tell me
    what is the low AC voltage (12V - 30 V) analogue of TRIAC (used at 220V AC)
    which can be used as a switch (having low resistance when switched ON) with a ON/OFF DC signal used for its switching.
    I can use relays (electromagnetic switch which can provides low resistance when switched on) but is there any other alternative from semiconductors devices which can work in the similar way as a triac or relay( it should provide low resistance when switched ON).
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Try something like a solid-state relay.
  3. mrmeval
    Distinguished Member
    Jun 30, 2006
    833
    A solid state relay. You can get ones that are activated by 3-32vdc or ones activated by line voltage.
  4. vaibhav_ait04
    Dec 13, 2006
    solid state relays are used for 115/220V AC (switched ON by 3- 32 V DC)
    I wanted to know the Semiconductor device which can be used for 10 - 30 V AC
    (activated by low DC/AC voltage)
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    They are rated for 115 VAC, but they work fine for lower AC voltages. You can find them that use 10 VDC to switch.
