Trying to design a small unreg. power supply for my project. What is the difference in the two setups of the power supply ?
Please see the attached image.
What is the difference bitween the two unregulated supply ?. If 220vac varies from 170vac to 270vac will the output decrease and increase the same way for both, or there will be a difference in out put voltage and or current ?
Pls. help understand the difference.
