Help needed:Converting HEX to DECIMAL
Discussion in 'Programmer's Corner' started by weiix05, Apr 8, 2009.
  1. weiix05
    Apr 2, 2009
    15
    I am using visual basic 2005 for my project. I am done with the part reading th values from the board. The values come out in HEX so i need to convert it to decimal,can anyone help me with the code for visual basic 2005 to convert HEX to decimal.
    Thanks.:)
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Do you possibly have a function named hex2asc or hex2dec in the library?
    hgmjr
  3. weiix05
    Apr 2, 2009
    15
    PublicClass Form1
    PrivateSub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
    Call Read()
    EndSub
    PrivateSub Read()
    Dim value AsInteger
    Dim hex_val AsString
    If SerialPort1.IsOpen Then
    SerialPort1.Close()
    EndIf
    SerialPort1.PortName = "COM1"
    SerialPort1.BaudRate = 9600
    SerialPort1.Parity = IO.Ports.Parity.None
    SerialPort1.DataBits = 8
    SerialPort1.StopBits = IO.Ports.StopBits.One
    SerialPort1.RtsEnable = True
    SerialPort1.Open()
    SerialPort1.WriteLine("U2" + vbCr)
    TextBox1.Text = vbNewLine & "....Work in progress...."
    TextBox1.Refresh()
    System.Threading.Thread.Sleep(150)
    TextBox1.Text = ""
    TextBox1.Text = SerialPort1.ReadExisting
    SerialPort1.Close()
    EndSub
    EndClass
    this is currently my code, i need to change the hex values to decimal in the textbox.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    You might try ToInt32() function...
    Dim Hex_val as string = "ABC111"
    Dim
    i As Integer = Convert.ToInt32(Hex_val, 16)
    should give i=11256081
    This works for VB2008
  5. weiix05
    Apr 2, 2009
    15
    Sorry i am new to Vb2005, i dont understand about the function part. I am so sorry, can tell me where to put it?
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    From what I can deduce from your code you have the following, so far:-
    A button - "Button1"
    A text box - "TextBox1"
    A serial port interface - "SerialPort1"
    You click the button to open the port through a private subroutine "read()" and send an ASCII string "U2" with CR. Whenever you send the data you write the phrase "....Work in progress...." to the text box. You sleep 150ms to enable the serial port to load in the received data.
    Two variables - "value" [an integer] and "hex_val" [a string] are declared but not used.
    Your code appears incomplete - you read data from the port which will probably come as a hexadecimal string. When data is read it is copied into the text box - as the hex string not as the integer value.
    If I understand you correctly, it seems you actually want to convert the received hex string to a decimal (integer) equivalent first then write to the text box.
    So you need some extra code to :-
    1. copy the hexadecimal string to string variable "hex_val"
    2. convert the hexadecimal string to an integer "value"
    3. place the integer value in the text box.
    Therefore I would modify / add code as follows ...
    after the line
    TextBox1.Text = ""
    delete the line - TextBox1.Text = SerialPort1.ReadExisting
    then insert the following lines..
    hex_val = SerialPort1.ReadExisting
    value=Convert.ToInt32(hex_val, 16)
    TextBox1.text=str(value)
    Everything else stays the same.
    That might get you closer to a solution if the port read works OK - as you indicate it does.
  7. weiix05
    Apr 2, 2009
    15
    Thanks tnk, but i am still facing some probs.
    PublicClass Form1
    Call Read()
    EndSub
    PrivateSub Read()
    Dim value AsInteger
    SerialPort1.Close()
    EndIf
    SerialPort1.Open()
    TextBox1.Refresh()
    TextBox1.Text = ""
    value = Convert.ToInt32(hex_val, 16)
    TextBox1.Text = Str(value)
    SerialPort1.Close()
    EndSub
    PrivateSub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) HandlesMyBase.Load
    EndSub
    EndClass
    this is my edited code according to your help,
    but there is still an error when i debug it.
    value = Convert.ToInt32(hex_val, 16) --->the error is could not find any recognizable digits.
  8. t_n_k
    Mar 6, 2009
    5,448
    783
    Not really sure - Looks like there may be no valid ASCII printable data received at the serial port from the connected device or non-printable leading bytes such as control characters. I'm guessing you must be receiving something - since you see hex characters being received. Do the hex characters you see look as if they are printable ASCII - check any ASCII / Hex table.
    http://www.serial-port-monitor.com/index.html
    Download the above free serial port monitor and run this before you run your application - it can provide a watch of the port transmissions which might prove useful.
    You may have to extract the ASCII printable characters from the incoming data stream before conversion to ASCII format using the Convert.ToInt32(hex_val, 16) instruction. What's the data format you expect to see from the connected device - i.e. "the board"?
    It might also be worth adding a sub which is waiting for data to actually arrive at the port - rather than just using a 150ms sleep.
    Like this ...
    Private Sub SerialPort1_DataReceived(ByVal sender As Object, ByVal e As System.IO.Ports.SerialDataReceivedEventArgs) Handles SerialPort1.DataReceived
    [Insert Code for ... whatever you want to do with the data, including stripping out non-printable characters]
    End Sub
  9. weiix05
    Apr 2, 2009
    15
    Thanks tnk. Now i was told to extract the last 3 digits of the hexadecimal i received den covert it one by one to decimal. Can someone pls help me?
    Thanks.
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    What is the incoming hexadecimal sequence - is it a fixed length and how many bytes are received? Is there a fixed byte that always precedes the three bytes of interest?
    You need to ignore any bytes preceding the three important ones but you need to know which ones to ignore.
  11. weiix05
    Apr 2, 2009
    15
    Etc of the hexadecimal is U207F. But i dont need th first two values. I just need to convert the last three values one by one to decimal. I did manage to covert the numeric number but once it come out in alphabet i cant convert.
    Private Sub Convert()
    Dim LastDigit As String
    Dim intLastDigit, intSecDigit, intFirstDigit As Integer
    LastDigit = TextBox1.Text.Substring(4, 1)
    intLastDigit = LastDigit * 16 ^ 0
    Dim SecDigit As String
    SecDigit = TextBox1.Text.Substring(3, 1)
    intSecDigit = SecDigit * 16 ^ 1
    Dim FirstDigit As String
    FirstDigit = TextBox1.Text.Substring(2, 1)
    intFirstDigit = FirstDigit * 16 ^ 2
    TextBox2.Text = intLastDigit + intSecDigit + intFirstDigit
    End Sub
    End
    Class
    this is my code to convert only numeric number.
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    Which you could do as ..
    PrivateSub Convert()
    Dim my_str as String = Textbox1.Text.Substring(2,3) ; Form the 3 digit string.
    TextBox2.text=Convert.ToInt16(my_str,16) ; Convert it to integer value & display it.
    EndSub
  13. t_n_k
    Mar 6, 2009
    5,448
    783
    The only thing I'm not sure of is whether VB2005 does the Convert.ToInt() thing. I'm using VB2008.
  14. t_n_k
    Mar 6, 2009
    5,448
    783
    Otherwise use
    TextBox2.text=ConvertToint32(my_str,16)
    You can always upgrade to VB2008 - it's free!
  15. t_n_k
    Mar 6, 2009
    5,448
    783
    Or do it this way ....probably much easier to appreciate. Hopefully it works!
    my_str="&H"+my_str ; Now it looks like HEX format
    textbox2.text=Val(my_str) ; Val knows how to handle hex formats.
    EndSub
    You can just do it in one line ... it's a matter of convenience.
    textbox2.text=Val("&H"+my_str) ; Val knows how to handle hex formats.
  16. t_n_k
    Mar 6, 2009
    5,448
    783
    Strictly speaking Val should be made string type before putting in the textbox .. 'though VB2008 doesn't object.
    i.e.
    Textbox2.Text=Str(Val(my_str)) ; Make the value a string type.
    Don't use semi-colons as comment delimiter in the code BTW!
    That's all done for me .... good luck! Sorry about the interminable posts! Nice long thread!
  17. t_n_k
    Mar 6, 2009
    5,448
    783
    A small P.S.
    I forgot about the CInt() function as well
    Textbox2.Text=Str(CInt(my_str))
    also gives the same result as Val()
    where my_str="&HXXX" for your case & X can be any of hex values 0,1,2,3,....,A,B,C,D,E,F
    So you have several options .....something should work for you.
  18. weiix05
    Apr 2, 2009
    15
    Thanks tnk for the long long thread(:) i can convert to hex alrd.
    THANKS SO MUCH TO ALBERTO TOO.:)
