Help Needed C Programming
Discussion in 'Programmer's Corner' started by Ralf, Mar 17, 2009.
  1. Ralf
    Thread Starter Active Member
    Mar 16, 2009
    31
    i have a problem with this:
    let say i type in 7 and it will display a 25
    and the max i can type in is 10 and the display number max will be 29
    how to i program with this condition using C language?
    sorry if u all don't understand what i trying to ask.. please let me know that the information is not clear, so that i can ask my friend to help me rephrase.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    What is the formula to convert 7-> 25 and 10->29
    When you say the Max would display as 29, are there other numbers it could display when 10 is entered?
    Are the numbers base 10, hexadecimal, octal, or "other"?
    What are you using for a keypad for numeric entry?
    Which microcontroller/compiler? (this doesn't matter too much, but they aren't all perfectly compatible)
  3. Shmurk
    Member
    Aug 13, 2007
    24
    I know nothing about it but here's a beginning of a solution:
    7 is 25, 10 is 29, which "could" mean that we increase the value with 4/3 at each step, like this:
    • 7 -> 75/3
    • 8 -> 79/3
    • 9 -> 83/3
    • 10 -> 87/3
    and if we go "down" instead, the first value is: 0 -> 47/3.
    So a formula "could" be: f(x) = 47/3 + (x * 4/3), which is in C:
    Code ( (Unknown Language)):
    1. float f(float x) {
    2.     return 47.0/3.0 + (x * 4.0/3.0);
    3. }
    Edit: If the "max" is 10, then the code would be:
    2.     if (x >= 10) return 29;
    3.     return 47.0/3.0 + (x * 4.0/3.0);
    4. }
    or something...
  4. Ralf
    Mar 16, 2009
    31
    to thatoneguy
    1st qns: no.. the max is 10. and it must display a 29 on my 2 LED
    2nd qns: is a decimal number
    3rd qns: is a thermistor that sense temperature and i will convert this using ADC to display in 7 segment.
    4th qns: Microchip PIC18f24k20 , is a C compiler( when i install C compiler it include mcc18 file inside.)
