Michael620
- Joined May 8, 2013
- 7
Do you know the direction of the current in the zinc wire connection where you want the resistance?
Amazing! Does the MOSFET get warm?It's still in breadboard stage, but it worked perfectly the first time.
I put the 25 turn mini potentiometer in the middle of its setting and came up with -0.540 volts on the thruhulls. A couple of turns, and the voltage is at -0.550 and rock solid.
No noise on AM, short wave at all.
Thanks to Ron H. and all who contributed to this project.
I hope I can return the favor someday.
Steve
Thanks. Maybe that will help me set up my spice simulation.The original circuit was a small panel mount analog meter in series with a wirewound pot. The meter required about 20 milliamperes for full scale.
The current (at least at today's salinity level) from the zinc to the bonding system with a Fluke meter connected between the zinc and the bonding system and no other circuit in place gives about 60 ma.
I didn't measure the voltage between the silver and the bonding under those conditions, sorry I should have but I'll bet it's almost a volt.
That's the original setup where the bottom paint was being damaged, and the reason for your help with the circuit.
With your circuit in place and -0.550 volts dialed up, the current varies of course with the salinity changes, but seems to average around 15 ma or so.
The thing that makes for confusion is the changing salinity.
Being in the Pacific NorthWET we have rain which being less dense, floats on top of the salt water in the canals, the tide which flushes it out and replaces it with salt water.
This makes it tough to get concrete scientific data.
Not sure why you made that change, but the results are the same either way.BTW, I did not connect the Ref and Cathode of X1 together as in your diagram. The Ref goes to the pot slider and the Cathode goes to the 4.7k and the end of the pot.
I'm waiting to see if it still does what you want when the salinity changes. My first try at simulation wound up with the circuit latching up, with the MOSFET on all the time.Ron,
Everything's installed and working.
About 20 milliamps at -0.560 volts on the thruhull bonding system wire.
I do get a sampling ZZZzt in the AM radio about every 45 seconds.
The sampling rate doesn't need to be that fast, so I'll take your advice on slowing the rate with a cap to ground from the + input on the op amp.
It would be fine with me if it had a sampling rate of 5 minutes or so.
I'll get there quickly enough with my handy dandy capacitance substitution box.
It sure is great to see a regulated voltage on my bonding system ! Thanks a million for your help.
Steve
Please keep us posted if the voltage changes significantly.It's holding within roughly 0.01 volts over several days now.
I found part of the problem of the previous voltage swing which had nothing to do with the circuit.
It was a corroded connection at the rudder assembly which varied the zinc load by a considerable amount.
After repairing the connection and resetting the voltage at -0.560, it has never gone over -0.572 and is usually around -0.565.
That's a pretty close hysteresis which makes me one happy boater !
Steve
by Don Wilcher
by Jake Hertz
by Jake Hertz
by Duane Benson
