HELP NEEDED Alpha RF Transmitter/receiver
Discussion in 'Wireless & RF Design' started by icem, Feb 6, 2011.
  1. icem
    Nov 15, 2009
    26
    Hi
    I'm doing project in which i need to create a wireless link between a board and an LED display. I'm using RF modules for the wireless communication which i have already bought.
    I sort of understand how they work, however i can't figure out what certain pins on the receiver and transmitter do, or whether or not I'm gonna be needing them.
    I have attached the data sheets for the components, can anyone tell me what the functions of these pins are:
    Transmitter - Pin 13 - FSK Data Input
    Receiver - Pin 1 - FIFO fill interrupt (Active Low) / status read data output
    Pin 3 - FSK Data Output (non FIFO Mode) / FIFO Select
    Pin 4 - Clock Output (noFIFO) / External filter Capacitor(analog mode) / FIFO interrupt (active High) when FIFO level set to 1, FIFO Empty interruption can be achieved.
    Thank you very much
  2. phil5533
    May 29, 2012
    hi icem
    I know this is an old post but I am at the same stage you were. Did you get any usefull info back/links . Tks
