" Help needed- 4.2V@1.5A form 3.7V Li Ion battery "
mishra87
Joined Jan 17, 2016
1,039
Could anybody recommend me a device/chip under below specifications-
Input- 3.7V/1450mAh Li Ion Battery
Input Voltage range - 3-4.2V
output- 4.2V @1.5A
I need a step up (boost) converter under above spec.
mishra87
Joined Jan 17, 2016
1,039
GopherT
Joined Nov 23, 2012
8,009
That does not ship to India.
With the above supply i want to drive a stepper motor.
Means if the if input voltage of battery is 3.3V , the output should be 4.2V for stepper motor driver which drives stepper motor .
Because at lower voltage the the performance of of the motor degrade. and there is some audible sound.
Stepper motors will whine in normal operation (like a transformer) because of the rapid charge and discharge of the coils in the motor. The iron actually changes shape under a magnetic field - google magnetostriction and other resonances of the system. (See "coil noise").
Here, a very creative person has some fun with the noise made by stepper motors - and controls the noise perfectly.
34,470
Note that your battery current will go up in proportion to the step up voltage divided by the boost converter efficiency.
Thus for a 90% efficiency boost converter form 3.7V to 4.2V @ 1.5A output, the battery current will be (4.2/3.7) /0.9 * 1.5 = 1.89A.
