i am trying to run 4x 2.8v 3mm white led lights using only 2.4v(2x 1.2v rechargeable batteries) is it possible and if so what do i need i have already goolged and havent come up with much
Garden solar lights use a voltage stepup circuit. some use the Joule Thief circuit and others use only an inductor and a couple of transistors.
There are many garden solar lights circuits on the internet.
Gee, I can hardly believe you're knocking the circuit I sent you to.
Sure, it might be a few years old. No, it's not the most efficient design on the planet. But if you had looked at the entire page, you would have seen that one can indeed be built very, very small, and very, very inexpensively.
Go ahead and buy that fellow's kit for $10 if you like. But if you shop around, you can buy enough materials to build dozens of Joule Thieves for that much money.
It looks like the kit the fellow's selling is a spin-off of a circuit that was published in Electronic Design Ideas awhile back. That one consisted of two 2N3904 transistors, five resistors, a capacitor and a 1N4148 diode plus the LED. This fellow eliminated the diode and a resistor somewhere.
You're free to use any design you like. If you're looking for small, cheap and easy to build, the Joule Thief is hard to beat.
[eta]
The BC549 transistor in Big Clive's Joule Thief can be replaced by a 2N3904; they're really quite similar.
You could use a great big toroid like they used on the Evil Mad Scientist if you want, but that's really overkill, and will make your project much larger than it needs to be. The small ferrite beads work just fine; they simply cause the circuit to oscillate at a much higher frequency than the large toroids would.
I bought a bag of ferrite beads from a local surplus shop for a quarter. I had a spool of 34 gauge wire on hand, along with an assortment of resistors and transistors. I built several of them, and I needed to keep them quite small and lightweight. They're used to align the rotor blades on a helicopter.
i dont wanna buy his i like the one you showed me but i need one that will last long because i will be installing this on a xbox 360 controller so i want it to last awhile and not suck all energy in an hour will the one you showed me last or is the other guys better
