Help need to build scrolling led dispaly....
Discussion in 'Embedded Systems and Microcontrollers' started by RRITESH KAKKAR, Jun 6, 2012.
  1. RRITESH KAKKAR
    Thread Starter Senior Member
    Jun 29, 2010
    2,831
    89
    HI,
    I need to build small scale without keypad scrolling text display by using PIC starting from PIC16f676....
    I have seen it working as scanning from left right like that.
    please guide me further!!
  2. MrChips
    Oct 2, 2009
    12,657
    3,461
    First, select your LCD display.
    RRITESH KAKKAR likes this.
  3. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I want to use LED display...
  4. nerdegutta
    Dec 15, 2009
    2,574
    807
    What type of LED display?
    Remember that first comes the hardware...
  5. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    As there are dot matrix display, ok i will use seven segment display that's fine..!!
  6. nerdegutta
    Dec 15, 2009
    2,574
    807
  7. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    OK, that will be fine...!!
  8. nerdegutta
    Dec 15, 2009
    2,574
    807
  9. RRITESH KAKKAR
    Jun 29, 2010
    2,831
    89
    I don't get you, pls tell again..
  10. nerdegutta
    Dec 15, 2009
    2,574
    807
    I was thinking you could do something like this:
    Link to big view.
    This circuit is by no means finished, but only as a clarification for what I would try to do. (Be sure to place a 0.01 uF cap near the PICs powerpin to GND. I forgot on the schematic.)
    This is just a thought. :)
  11. BMorse
    Sep 26, 2009
    2,675
    234
    You can start off with the same circuit here (use the part that connects to the displays only), and just replace the PIC16F628A with your choice of pic, this display is multiplexed with 4 digits...... and can be scrolled left to right or vice versa with code, you will also have to learn about multiplexing the displays in order for you to get the desired output.....
    http://forum.allaboutcircuits.com/attachment.php?attachmentid=18943&d=1272466284
  12. BMorse
    Sep 26, 2009
    2,675
    234
    That circuit will show the same digits on all 3 displays at once, there needs to be a way to select each digit to display appropriate data to it. Just a thought....
  13. absf
    Dec 29, 2010
    1,493
    374
    Using 4511 decoder would also limit the display of numbers only. You wouldnt be able to show simple sentenses like "HAPPY bIrtHdAY" as shown in your youtube video.
    Allen
  14. nerdegutta
    Dec 15, 2009
    2,574
    807
    Yes, thought of that later in the evening...
    It is not my youtube video. I only linked to it, as a suggestion to the OP.:rolleyes:
  15. MMcLaren
    Feb 14, 2010
    759
    116
    If you're using a "direct drive" design like this, you'll find you get better display brightness (better "average" current) when directly driving the cathode segments of common anode displays because the RDS(ON) for the I/O pin sinking FET driver is much lower than that of the sourcing FET driver.
    Unfortunately, "direct drive" starts to fall short, in terms of average current and display brightness, as you decrease duty cycle when adding more displays, which is one of the reasons why I came up with my MacMux method several years ago.
    Basically, the MacMux method allows re-tasking the column driver lines as <clk> and <dat> lines to load the driver IC shift registers in parallel (bit-banged parallel SPI) in about 24 cycles during a short blanking interval. The method also scales nicely for larger displays (see below) and using the PIC PWM signal to drive the </oe> and <lat> pins provides a simple mechanism for complete fade-to-black display brightness control.
    Food for thought.
    Cheerful regards, Mike
  16. BMorse
    Sep 26, 2009
    2,675
    234
    You are right MMcLaren, since pics would rather sink than source, but unfortunately this counter circuit was designed for another forum member that only had common cathode display's:(. And was not paying attention when I linked to this particular attachment...:rolleyes:
  17. nerdegutta
    Dec 15, 2009
    2,574
    807
    Excellent! Just had time to re-read post, and it was something like this I thought of. There is a difference in the pin count on the PICs, and I thought it would make the programming easier if all the 7-seg pins where on the same port. That's why I thought of the 4511 IC.
    BMorse and RRITESH KAKKAR like this.
  18. BMorse
    Sep 26, 2009
    2,675
    234
    @ RRITESH KAKKAR: What kind of seven segment displays do you have, common cathode or common anode??
  19. BMorse
    Sep 26, 2009
    2,675
    234
    Just a thought, with that many LED matrices, why not use a matrix driver such as the MAX6952 or similar? Would reduce component count quite a bit, and does everything your circuit does.....
  20. MMcLaren
    Feb 14, 2010
    759
    116
    Hi Brent,
    That's a fine chip. Nice voltage range. Lots of features. It would certainly reduce 'overhead' and the number of I/O pins required on the host mcu. A bit big and a bit pricey though, coming in around $24 a piece at Mouser, but you could probably sample one or two of them for a "one off" project. Maxim lists a hobbyist friendly 40 pin DIP package but Mouser doesn't seem to have it.
    Yep, you'd only need three Max6952 drivers ($72) for that 7*45 matrix compared to six 74HC595 drivers ($2) or six TPIC6C595 drivers ($8) and a few dollars worth of MOSFETs. Though, there would be less of a difference in component count if I were to use 16-bit constant current driver ICs. In that case I would only need three 24-pin TLC5926 or similar driver chips instead of the three much larger 36 or 40 pin Maxim chips. Of course I'd still need the MOSFET drivers. Price and component count aside, I wonder which set of drivers would actually have a smaller PCB footprint?
    As for doing everything... does it really? I don't see how you could use a proportional font with it. You're pretty much stuck with the built-in font and whatever you can do with 24 user definable characters. And what about scrolling left or right one column at a time? Or, scrolling up or down one row at a time? It kinda looks like you're stuck moving stuff one 5x7 character at a time, doesn't it? And, while 16 brightness levels on the MAX6952 is good, I typically use 64 to 100 gamma corrected brightness levels spanning 256 or more PWM steps for smooth fade capability. Finally, since the MacMux driver has control of the row or column driver lines, it's easy to form a column driven or row driven switch and/or encoder matrix using a minimum number of host I/O pins for switch matrix input. I don't see an easy way to do this on the MAX6952.
    Don't get me wrong. It's a great chip with lots of very nice features. I just don't think an economical hobbyist dot matrix moving message display is one of the applications it was intended for.
    RRITESH KAKKAR and BMorse like this.
