Hi All
I'am thinking of using a sa602 chip, not used one before, To down-mix 9Mhz to 455Khz for am\fm detection.
Not sure if i have got things right with IC1, i have a crystal of 8.545Mhz connected as the osc, pin 4 of IC1 go's to a 455Khz filter,
then on to a TCA440 AM IF chip (not sure if thats a good chip to use).
For FM, use another 455Khz filter diode switched to a FM Detector with squelch (not sure what chip to use here).
For SSB, use another sa602(IC2) with the input coming from a cascade MC1350 9Mhz if amp with agc, and feeding the BFO Osc (8.985Mhz and 9.0015Mhz) into pin 6, and hoping that SSB Audio will come out of pin 4.
Is this the right way to use the SA602 chip ??
Thanks for any help
Hamopp.
This is the Circuit:
Thanks for any help
Hamopp.
