Help need for amplifier for stereo speaker system
Discussion in 'The Projects Forum' started by BrainlessDan, Sep 21, 2014.
  1. BrainlessDan
    Sep 21, 2014
    Hi guys,
    I am currently in the middle of doing a project where I am trying to make a stereo speaker system. (I know it doesn't seem hard but I'm new at it all).
    Anyway, I am aiming to use a woofer and tweeter in conjunction with the use of a 2 way connector and splitting the frequency at 2500 Hz. Here are the links to the woofer and tweeter in question :
    Tweeter : http://www.parts-express.com/goldwood-gt-525-1-soft-dome-tweeter--270-182
    Woofer : http://www.parts-express.com/dayton-audio-dc200-8-8-classic-woofer--295-310
    (And I know there not brilliant speakers but I'm trying to this on a small budget)
    I have already calculated the volume of the enclosure for the Woofer using a program called WinISD from linearteam.
    But unfortunately that is as far as my knowledge goes on the matter, and I was wondering if any of you guys could help to work out how to make the amplifier and the 2 way connector as I haven't got a clue how to do so. So anyway help or advice would be greatly appreciated.
    P.S I will be needing to reference any advice I use, as I need to record all resources used. Hope this is okay.
  2. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  3. crutschow
    Mar 14, 2008
    13,501
    3,375
    What do you mean by "make an amplifier"? Do you want to do it from scratch? If you want to build it, a kit with a circuit board makes life a lot easier and likely will cost less than buying all the parts separately.
    And what do you mean by "2 way connector".
  4. BrainlessDan
    Sep 21, 2014
    What I mean is I need to make a amplifier that works with those speakers but I have no idea how to do so, I mean two way crossover unit (don't know where i got connector from)
  5. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
  6. #12
    Nov 30, 2010
    16,704
    7,351
    MaxHeadRoom likes this.
  7. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,523
    I agree some of the deals coming out of China are very tempting, I recently put together a small piece of test equipment, and could have sourced the same from China for $8.00 p/p, but I had all the parts on hand, still, unless you are doing it for academic reasons, is it worth the time?
    Max.
  8. #12
    Nov 30, 2010
    16,704
    7,351
    You never know with beginners. Some of them become enamored with transient response and want a 400 watt Crown amplifier for a 40 watt speaker. :rolleyes:
    Personally, I like to make my amplifier rated for 1/2 the power rating of the bass speaker. That way, you (almost) can't blow your speakers up, even if things go terribly wrong.
  9. Experimentonomen
    Member
    Feb 16, 2011
    331
    46
    For a beginner diy amplifier, i cannot recommend the LM3886 enough, its a simple rugged pretty much indestructable lil amp ic capable of around 40-50 watts into 4 ohms. You don't even need a PCB to build one. Also you'll have a hard time finding a better sounding amplifier.
    #12 likes this.
  10. crutschow
    Mar 14, 2008
    13,501
    3,375
    Parts Express, where you are getting your speakers, has many assembled crossover networks.
  11. #12
    Nov 30, 2010
    16,704
    7,351
