HELP: Need diode switch for audio path switching
Discussion in 'General Electronics Chat' started by hamopp, Jun 24, 2009.
  1. hamopp
    Thread Starter Active Member
    May 13, 2009
    68
    Hi all
    I need to be able to switch a common audio input!
    This is how its done with a switch
    But i need to have it done with diodes, and i have +12 switch lines
    from the logic board.
    Can any one help with this ?
    Regards
    Hamopp
  2. steveb
    Jul 3, 2008
    2,433
    469
    If you are trying to do the switching electronically with logic signal control, then CMOS analog switches such as the CD4066 are a good choice.
    http://www.maxim-ic.com/appnotes.cfm/an_pk/638
  3. hamopp
    May 13, 2009
    68
    Hi
    Thanks for that info, looks like they are the way to go.
    Regards
    Hamopp
