Help MOSFET need replacing .
rastaman46
Joined Nov 17, 2011
75
Hi
I got car universal laptop charger that had short and now 12V just flow true without boost.
Its one of them chargers
I took it apart and found one mosfet is Cracked
Mosfet "P60N06"
I removed it so got question here what i can use to replace it?
rastaman46
Joined Nov 17, 2011
75
MTP60N06 - 60V/60A/14mΩ.
NTP60N06 - 60V/60A/14mΩ.
I just wondering does this adaptor really need the current as this mosfet?
I got loads 12V chargers is any way i can remove mosfets from there and use it as replacment?
i got Mosfets "STPS3045CT" "K2842"
All i want to do is just make it run from stuff i can get NOW cause i need it for fishing tomorrow night :D
I can buy but ill take few days to receive it that all
all i want is make it run for atleast 19V
LDC3
Joined Apr 27, 2013
924
STPS3045CT is not a transistor.
K2842 will work as long as the current is below 12 A continuous, or 40 A pulse (provided you stay below the heat dissipation required).
rastaman46
Joined Nov 17, 2011
75
Thanks for answer
Replaced but still only 12V true no boosting :(
Can any one tell me what can cause it ?
Screens:
rastaman46
Joined Nov 17, 2011
75
To the far right of the IC, is there a bridging solder connection?
No not Bridged
It was working till it got short and after that all i get is 12V
12V in and 12V out even if its set to 24V :confused:
All i notice is that 8 feet transistor gets hot but coil do not
