I have two identical thermistors. I will refer to them as sensor A and sensor B. Sensor A reports the vessel temp. while sensor B monitors the output of the heater. The original heater had just a 2 degree temperature differential. The new heater that must be used produces a temperature rise of 8 degrees F. on sensor B. What I am trying to do is automatically modify sensor B to read no more than 2 degrees hotter at any time than sensor A, using A as a reference through it's temp. range.
An example of the resistance readings at two ends of the temperature range for this project is as follows: At 59F tank temperature sensor A is 48,840, heater is putting out 67 degrees so sensor B is about 40,000, difference of 8840. At 104F sensor A is reading 16,149 and sensor B is 112F @ 13,500 a difference of just 2,650. So I need a clever way to add 8000 ohms or so when colder and gradually reduce using A as my reference as temp. climbs to finally just 2500 when warmer.
Thank you in advance for your suggestions.
