1. ahmed hammad
    Jul 4, 2010
    9
    i want learning programming language c++ and because i learn after that
    microcontroller so i want know can programming microcontroller by c++ and that's easy or assemply ?
    plz more explain
    i hope my question is clear
    thanks
  2. debjit625
    Apr 17, 2010
    790
    186
    C++ is an Object Oriented Programming Language(OOP) and in embedded systems like microcontrollers you cant use OOP we need a system programming language like C by the way its an Object Based Language .You have to learn C to program microcontrollers and its easy from assembly (or you can say its code is more mantained,structured).On the other hand is assembly ,you should learn it as well because it will help you to understand the microcontroller's system architecture more clearly.
    Good Luck
  3. rajbex
    Nov 2, 2009
    22
