help me!
Discussion in 'Homework Help' started by chyadesh, Aug 28, 2009.
  1. chyadesh
    Apr 10, 2009
    19
    Q) can u please tell me the difference between the reverse active region and forward active region.? please provide ur answer with suitable example so that i can understand it well....
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    For what components are you looking for?
    Greetings,
    Bertus
  3. wwchieh
    Member
    Apr 25, 2009
    14
    I am guessing that you are asking about BJT.
    Let's take BJT npn for example. In BJT npn, we have a higher doping n-sub than the other n-sub. Usually, the higher doping n-sub will be the emitter and the lower doping n-sub will be the collector.
    Forward active region is occurred when the base-collector is in reversed bias and the base-emitter is in forward bias. The current enters from collector and exits from emitter.
    Reverse active region is occurred when the base-collector is in forward bias while the base-emitter is in reversed bias. The current enters from emitter and exits from the collector.
    Forward active region has a higher gain than reverse active region. So, we prefer to use forward active region in amplifying our circuits.
