I have a problem about making an negative regulator, which have parameters following
+ Vin = 40 V
+ Vout = -12V
+Iout = 1A
I need schematics not use transformer. Help me please
Thank you every one seeing the thread!!
Sory, i have only input, with is 40VDC. I want to make a negative voltage -12 V from the input without pulse transformer. I need a schematic buck-boost converter.
How many outputs do you have? If there is just the single -12V output then the aforementioned LM7912 will do the trick, along with many other devices equally simple and suitable.
If you are using the input for a positive output then sorry kid, it cannot be done without a transformer (for isolation) inside a switching converter.
