and another one question. Can the current that is produced by the motor to make a wave with frequency analogical to the current? i find more difficult the idea about hall effect or IR detector to built it ( the construction ).
Before you go running off I would like to say something. Do you want to simply generate sound with its frequency proportional to the rotation speed of a muffin fan when wind is rotating it? If your answer is yes then simply use an AC muffin fan, Put two diodes across the leads and plug it into your PC's or amp's Mic jack.You have given me food for thinking and reading for a long time now... Thank you, i will try to solve my problem on the ideas you gave me, and for any new problem, i will write in the forum.
Thank you. Thats what i was searching for, from the begining. Simple and exactly what i was searching for i think.Here is something to get you in the ball park.
I just breadboarded it and it works good for changing freq. sound with the turn of the motor shaft.
Also if you turn the motor backwards the freq. pitch drops too.
So you can make it increase in freq. and decrease according to shaft rotation.
They prevent the input to the Mic jack from exceeding .7V. I did not employ a series current limiting resistor because these fans are HiZ.what are the protection diodes. whet protection offer?
