Help me with Voltage to Frequency problem
Discussion in 'The Projects Forum' started by electrobuzz, May 10, 2009.
  1. electrobuzz
    May 10, 2009
    14
    Hi, thats my first post in the forum.
    I'm new to electronics and i would like you to help me with a small project.
    I want to make a circuit in which i will have a fan (like those in pc's or just a motor) and according to the speed it will spin because of my blow , a speaker in the circuit will produce a tone that when the fan spins faster the frequency goes up.
    Thank you in advance .:)
  2. PRS
    Aug 24, 2008
    989
    35
    You can spin an alternator and its output will be a sinewave with a frequency determined by the speed of rotation. So if you spun it with a variable speed motor you'd produce a tone that varied in pitch by the speed of rotation.
  3. zero_coke
    Apr 22, 2009
    294
    For this project you would need a Variable Frequency Drive (VFD) to control the RPM of the fan to make different sounds at different speeds.
  4. CDRIVE
    Jul 1, 2008
    2,223
    99
    Is this a class assignment?
  5. electrobuzz
    May 10, 2009
    14
    Thank you for you replies.
    But i don't want to have just different frequency for different motor rpm, but i want when I rotate the motor (which will not be spining on itself) the frequency to change. And i want to have a tone and when the motor don't spin, which tone's frequencu goes up when i start to rotate the motor ( blowing to the fan)
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    Unfortunately I don't understand what your requirement is. Maybe others are in a similar situation. Would you kindly restate the problem using a different wording perhaps - a simple diagram is always helpful.
  7. electrobuzz
    May 10, 2009
    14
    Oups , sorry for the wording, excuse my english.
    I made a diagram that beleve shows what i want .
    The motor has a fan. When i set it to motion by blowing to the fan , I want to have a linear correlation (if possible) between frequency and velocity.
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    It would appear that the OP wants to demonstrate (using a speaker as an output indicator) that a small blower will output current (like an Alternator) at a frequency proportional to the RPM.
  9. eblc1388
    Nov 28, 2008
    1,542
    102
    I think the OP wants to use a simple fan as an anemometer, with variable sound pitch as output.
    A stationary fan connects to a circuit producing a 1KHz tone. If he blows on the fan blades to make it spin, he wants the circuit to give increasing frequency output to speaker as per rotation speed of the fan. Faster spin, higher frequency note from speaker.
  10. electrobuzz
    May 10, 2009
    14
    Exactly that i want.
  11. CDRIVE
    Jul 1, 2008
    2,223
    99
    How does a stationary fan (not rotating) produce 1KHz? :confused:
  12. PRS
    Aug 24, 2008
    989
    35
    Electrobuzz, I think I understand you now. Your interest is in measuring wind speed using a transducer that produces a frequency that is linearly related to wind speed?
    I don't know that such a device is not commercially available, but it seems that you could make one with a little ingenuity. I should think you'd want to make an easily turned 2 pole alternator with windings of magnetic wire. Then output this into a linear amplifier, or digitize the signal using a comparator. Once the signal is digitized it can be analyzed by digital logic devices.
  13. electrobuzz
    May 10, 2009
    14
    Not the fan. The circuit produce 1KHz itself, and the motor when is setted to motion the frequency changes.
  14. electrobuzz
    May 10, 2009
    14
    Yes . That's what i want.
    Could you help me more with logic devices needed, and about the assembly?
  15. PRS
    Aug 24, 2008
    989
    35
    There are so many electronics people nowadays automatically think PIC microcontroller as soon as a situation like this comes up. But there are often better ways. I think this is one of those cases. But before I can really determine this I need to know what kind of output you want. If it's to be processed by way of logic in a sophisticated manner, then the microcontroller might be the best way. But if you just want to get a simple frequency versus windspeed, then there is a more simple approach. I mean this latter approach is like hooking a frequency counter up to your transducer and consulting a table or formula of frequency = windspeed. And in this case an experimental approach involving finding a suitable transducer with a corresponding table or formula is the key.
  16. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    how about a transistor oscillator to idle at 1khz. then put the fan in the bias circuitry to alter the frequency of the oscillator.
  17. electrobuzz
    May 10, 2009
    14
    I want by measuring the output frequency to be able to find the windspeed. The idea is to connect the output to an audioin of pc or other device and see the frequency.
  18. CDRIVE
    Jul 1, 2008
    2,223
    99
    You would be better of constructing your own rotating blade with output being derived from a Hall Effect or IR detector. This is how portable tachometers work.
  19. PRS
    Aug 24, 2008
    989
    35
    CDrive has the right idea. There are many ways to create a pulse train as a function of rotation. But why do you have to have 1kHz when there is no rotation? That just complicates the problem. But in this case you might make an oscillator that puts out 1kHz and send its output to a mixer. The other input to the mixer is pulse from a rotating machine. The output of the mixer should be 1kHz plus or minus the frequency of the rotating transducer. Use a filter to grab the sum. Then wind velocity = 0 corresponds to 1khz and wind speed is 1kHz+pulse speed. This project requires experimentation in order to deternmine the relationship between rotational speed and wind speed.
  20. electrobuzz
    May 10, 2009
    14
    Yes , i understund the expirimation part about the relation of rotational speed and wind speed. But the output of the mixer ( what mixer? - i am very new to electronics ) will be the sum of frequencies?
    -- edit
    i will have sine wave? or pulse?
