help me with a 24v and 48v charging and overcharge disconnect circuit
Discussion in 'The Projects Forum' started by abiola.sunday, Jan 2, 2012.
  1. abiola.sunday
    Aug 30, 2007
    Hello all,
    please can anybody help me with a 24v and 48v charging and overcharge disconnect circuit diagram that I can incorporate in an inverter circuit with that range of the voltage specified above using the same low voltage(24v-0-24v) and (48v-0-48v) step down side of the inverter transformer to charge immediately mains voltage comes in from puplic power to charge my batteries, then how to incorporate it with my existing working circuit. Your contributions is highly needed in this regard. Thanks to you all.
  2. bertus
    Administrator
    Apr 5, 2008
    15,804
    2,389
  3. R!f@@
    Apr 2, 2009
    8,791
    771
    U can do this using comparators
    {ed}
    Using inverters with chargers is not for n00bs.
    Standalone inverter cum chargers have all the features. You do not need to build anything.
