Help me using ZMDI ZSC31050!!!
ishank3
Joined Nov 19, 2015
Hello Sir,
I am using ZMDI ZSC31050 ic for offest compensation of my pressure sensor having offset 230mv for 12v,100mv for 5v. The IC is not respondiong until 2mBar pressure. My testing range is 0mBar to 6mBar. please help me solve this problem.
Thank you.
sailorjoe
Joined Jun 4, 2013
365
Your ZSC31050 chip is fairly sophisticated, and we'd need more info to help you. For example, what pressure eyesore are you using, and is it a bridge sensor compatible with the the ZSC31050? You need a computer to talk to the chip. What's happening with that? Have you read the detailed datasheet for the ZSC31050?
http://www.mouser.com/ds/2/477/ZSC31050_DataSheet_Rev_1_11-205967.pdf
Do you have a schematic of your system? Sharing that would be most helpful.
