Help me understand SAM9260's clocks
Discussion in 'Embedded Systems and Microcontrollers' started by aleksazr, Jul 20, 2010.
  1. aleksazr
    May 16, 2010
    I've started programming AT91SAM9260 and some
    things are not clear to me.
    At first, sam-ba was giving me problems
    so I created a small win32 app to mimic sam-ba.
    On reset, sam9260 sends "RomBOOT>" and then listens to commands.
    I then issue some commands to write to internal SRAM
    and then execute it. All that works.
    Speed is what interests me now, so I set the led,
    then clear it, in a loop. There are some 80 sets/resets
    and one jump, to minimize jump's execution time effect.
    The instruction are:
    str r3, [r2, #-203] ; 0xcb // clear
    str r3, [r2, #-207] ; 0xcf // set
    I have a 18.432 MHz clock, and this what I use for PLL:
    #define PLLA_SETTINGS 0x2060BF09
    or, to write it in a more readable way:
    #define DIVA 9
    #define PLLACOUNT 63
    #define OUTA 2
    #define MULA 96
    #define PLLA_SETTINGS (1 << 29 | MULA << 16 | OUTA << 14 | PLLACOUNT
    << 8 | DIVA)
    PLL's R1,C1,C2 are 1k, 10n and 1n, as in all schematics.
    Before I work with the PLLA, I first switch from PLLB
    (romboot was using it) to slow clock as the master clock.
    The fastest I got was 40ns per instruction.
    (i.e. 40ns per set, 40ns per clear)
    and that is only if MDIV field in PMC_MCKR is set to 00
    (master clock is processor clock).
    If MDIV is 01 (master clock is processor clock divided by 2)
    then I have 60ns per instruction. If it were 80ns, that
    would make more sense... but it isn't.
    First of all, I thought that master clock has nothing to
    do with CPU clock, with the execution of CPU instructions.
    I thought that Master clock is for SDRAM, peripherals,
    sampling the inputs, etc... but not for CPU instruction clock.
    Or, are instructions accessing peripherals executed
    differently than others?
