Help me to get an IC
Discussion in 'Electronics Resources' started by Santhakumar, Mar 17, 2015.
  1. Santhakumar
    Mar 17, 2015
    33
  2. MCU88
    Member
    Mar 12, 2015
    360
    35
    Hello...
    I am not quite sure what you want me to help you with... Can you elaborate a bit more on what it is that you want. Please add in requirements analysis and specifications for your project too.
    Easy greasy...
  3. Santhakumar
    Mar 17, 2015
    33
    Hi MCU88,
    I will put this way..
    Consider output load.. To feed power to load, i have two input power rails (5v and 3.3v). load requires only 1.8v. so i can use a LDO to get 1.8v from either 3.3v or 5v.
    At given time, IC i yet to be chosen s'd proceed any one rail (3.3v or 5v) to load, depends on input i'm giving through control I/P..
    Hope u would get my point..
  4. JDT
    Feb 12, 2009
    658
    85
    If only one power rail exists at any any time, 2 diodes would be the simple answer.
    If you have both and want to switch, then 2 transistors are needed, ideally MOSFETS. Plus a controlling circuit. The diodes will still be needed.
  5. Brevor
    Apr 9, 2011
    282
    56
    SPDT relay ?
