Help me to design a transistor amplifier at high frequencies
Discussion in 'General Electronics Chat' started by dumindu89, Aug 1, 2012.
  1. dumindu89
    Oct 28, 2010
    I need to design a transistor amplifier which has voltage gain of 30 @ 100 MHz. Since this is a higher frequency, I think I have to consider about the current gain - bandwidth product (fT) too.
    I hope to use 2N2222 (fT = 300MHz) or PN3563 (fT = 600 MHz) NPN transistor for the design.
    The problem is do I really need to consider the fT for my design?
    If yes, how I need to calculate the resistor and capacitor values (in voltage divider bias)? Is it OK to do the calculations as we do in small signal calculations?
