Help me to convert assembly to c(or c++) language
Discussion in 'Embedded Systems and Microcontrollers' started by hijack911, Dec 27, 2009.
  1. hijack911
    Dec 23, 2009
    My porject is: " Automatic Room Light Controller with Visitor Counter using Microcontroller." I've made it already in assemby but I can't run it in C.
    Please help me to convert assembly to C language!!! I'm very weak in C programming!:confused:
    Thanks all!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Out of curiosity, if it works as is, why does the code need to be translated to C?
    How do your sensors work?
  3. Papabravo
    Feb 24, 2006
    10,338
    1,850
    It is always possible to transform C or C++ into assembly language. It is not possible in some cases to do the reverse.
    My counter example is anything having to do with the carry flag. Since C and C++ have no semantics for dealing with a "carry" flag or a "borrow" flag, or an "overflow" flag any assembly program written to manipulate numeric quantities that involves these flags may or may not be translatable.
    If you think about it for a minute there are many examples of irreversible operations.
  4. hijack911
    Dec 23, 2009
    Thank to reply! But my advisor aks me to convert Assembly to C :(. I simulate a circuit on Proteus, it works very well. I mean that I replace sensor by switch(I'll press it to create 'pulse' to be considered people) for which delays to 0.2s. 0.2s is enough for people to cross sensors in reality.
  5. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Probably the point of the exercise was so you would learn C.
  6. Papabravo
    Feb 24, 2006
    10,338
    1,850
    It will be easier to write the application in C and not worry about doing a literal connversion. The point is to learn C, as Bill said.
  7. hijack911
    Dec 23, 2009
    i hopse so, i'll try it again but somebody can give me an idea, can't it?
  8. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Well what exactly are you looking for in the way of ideas?
    For example, evaluating an expression involving addition, subtraction, multiplication, and division should be straightforward. Regular loops should be rendered as one of the three loop types:
    Code ( (Unknown Language)):
    1.
    2. while([I]condition[/I])
    3.     [I]statement ;[/I]
    4.
    5. do
    6.     [I]statement ;[/I]
    7. while ([I]condition) ;[/I]
    8.
    9. for([I]initial; termination; increment)[/I]
    10. [I]  statement;[/I]
    11.
    Conditional execution is done with if...else... statements or a switch statement.
    Probably your biggest challenge will be to redo irregular control transfers, often referred to as spaghetti code.
  9. hijack911
    Dec 23, 2009
    I implement in C step by step.
    Thanks all and happy new year!. when i get a code C, i'll post it in forum where everybody can give me an advice for the best solution!
