Help me to build Small bluetooth device
Discussion in 'Embedded Systems and Microcontrollers' started by deviciw, Sep 30, 2013.
  1. deviciw
    Sep 30, 2013
    I want to build a very small bluetooth device
    The requirement is as follows -
    * The total device size is - 10x20x5 mm
    * The device will have a digital clock display
    * The bluetooth should receive signal from mobile phone and set the clock
    If anyone could help in building this, that would be great. I am even ready to pay for this.
    Thanks in advance
  2. Xkyve
    Nov 30, 2012
    What are you planning to use for display? 7segment, OLED? Do you want to display only hours and minutes, or seconds, too?
    Also, I'm guessing it has a battery?
    I don't think it's possible to build this device at those dimensions with off-shelf components.
