help me solve total resistance
Discussion in 'Homework Help' started by terrakota, May 20, 2005.
  1. terrakota
    Feb 8, 2005
    67
    hi,
    can u help me to solve the total resistance of this schematic?
    i think is 25k, but when i measure with multisim it givsme 13k
    thanks for any help
  2. David Bridgen
    Feb 10, 2005
    278
    The combination of R1, R2 and R4 is in parallel with R3. It follows that the combination of R1,2,3 and 4 is less than the value of R3.
  3. atferrari
    Jan 6, 2004
    2,668
    784
    Hola Terrakota:
    "Thinking" with the sense of your posting makes no sense. Instead, you have three options:
    1 - Use any program (you did) to calculate for you.
    2 - Breadboard that (95 seconds if all resistors available) and measure.
    3 - Calculate it using delta-wye tyransforms. Simple to do even if at the begining it seems difficult.
    I used delta-wye once to solve the famous resistor cube. You could look here:
    http://cablemodem.fibertel.com.ar/atferrari/ in "Theory, design & calculations"
    ¡Buena suerte!
    Agustín Tomás
  4. terrakota
    Feb 8, 2005
    67
    gracias
