Desktop is a device which isn't compact enough to be carried around and doesn't have built in battery.Please use proper terminology because it can cause confusion if its not right.Basically buy a new laptop since this one probably cant be repaired especially via the internet.but i prefer to bu a new desktop for 500€ then waste more 100€ on a mobo because the pc has 5 years and the proccessor(2.3 ghz) reachs 85º if i use trubo boost from intel (2.9ghs).
i know that, but i have other laptop with 7years old and it is enought for what i need surfing excel,word... next investement will be a desktop for heavy programs.Desktop is a device which isn't compact enough to be carried around and doesn't have built in battery.Please use proper terminology because it can cause confusion if its not right.Basically buy a new laptop since this one probably cant be repaired especially via the internet.
if i repeat the process , can it destry the chip?You should let the chipset cool down naturally.
Force cooling is not good.
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jeff Child
